Steve C
Platinum Member
While I understand what you are trying to say I will say I disagree with "you get zero benifit of the tensil strength of the reinforcing steel if it is centered in the slab".
For a real world concrete pour of 6", for example, with rerod centered would be like a 4'' slab with perfectly placed rerod.
But we cant assume that the top half is alway under compression. The edges of the slab would need the rerod placed near the top.
Many engineered slabs will have a mat of rod near the top and one mat near the bottom.
Duffster, Egon
After looking into the phisical properties of concrete (using the link that Egon provided) I must modify my view and agree with you 100%.
Concrete with rebar placed at the center of a thin slab will indeed benifit from the tensil strength of the rebar or wire mesh.
I had failed to consider the huge disparity between the compressive strength and the tensil strength of concrete. I am used to working with steel and it has much different properties. I think the disparity will shift the zone of zero stress much closer to the the surface that is under compression, be it at the top surface from a load or the bottom surface due to frost heaves.
The further away the reinforcment is placed from the loaded surface, the greater the benifit will be, but placing it in the center is a good option especially if you are not certain of the integrity of substrate it is being placed on.
Thanks guys, I think I learned something today......
