RockyNY
Looks like the concern would be tearing the SS plate off. You have a 90 degree angle between the horizontal tubes and the SS plate that is vertical. And you are pushing pretty high up on the SS plate. With no gussets or diagonal bracing, I can see that angle becoming more than 90 degrees.
IF it was me, I would mount it up to the tractor, then find a place to add some type of brace that works around the loader frame.
Another suggestion. IT appears that the fittings at the angle cylinders are not high pressure fittings. Rather they look like galvanized water pipe fittings. They are not rated for hydraulic pressures. If that is the case, I would remedy that ASAP
I did forget to mention, what you can't see in the picture is another 3x2 steel tube welded horizontally across the bottom on the front of the quick attach plate. The tubes holding the plow's A frame are extended out to the edge of this other tube (so 3" past the front of the QA plate) and welded all the way around as well. So from the point you can see in the pictures, where the bottom angled part of the QA plate slopes down and makes contact with the 3x2" tubes, the tubes extend 6" forward of that point and are welded in any place there is metal-to-metal contact. That's why I'm not much worried about the tubes breaking off the QA plate, but rather the tubes bending. I think the tubes are pretty much as strong or stronger than the A-frame, so there might not be any cause for worry. But I think I figured out a way to run some bracing, it won't be as ideal as what I had on there before, but better than nothing. Also, good eye on the fittings and yes you are correct about them. At the time I built it I didn't consider that the fittings weren't rated for hydraulic pressure. I do plan to re-do that part before next season though, it's held up through (almost) 4 winters, so hopefully it will hold up for a couple more plowouts.
