Stihl 261cm hard starting
   / Stihl 261cm hard starting #1
frogpond
Snohomish WA
Kubota BX25D
I have a Stihl MS 261CM, set up with 3/8 chain and lightweight bar, which I generally like. However, a cold start usually takes about 9 pulls, sometimes 12 when the weather is cold (Western Washington, so only in the 30s or 40s). After it's warmed up, 2 or 3 pulls to start, 1 pull if it's still pretty hot. I have replaced the fuel solenoid, and run the reset sequence. I use non-alcohol fuel with stabilizer added. I am at about 600 feet altitude.
Is there any way to make cold starts easier? Or is this normal for that saw?
   / Stihl 261cm hard starting #2
May want to check to make sure the choke is closing all the way. Have worked on a few stihl's recently were the choke was hanging up and not fully closing.
   / Stihl 261cm hard starting #3
that is not normal mine starts easily regardless of temp.
   / Stihl 261cm hard starting #4
Mine is starting on 3rd pull.
9-12 is too much.
   / Stihl 261cm hard starting #5
Isn't normal at all for the 261cm. Mine will start in 20 or 90 degree weather in 3 pulls max. Check your lines and filter and make sure they are clogged...
   / Stihl 261cm hard starting #6
I agree, it should start on third or fourth pull. With mine I go full choke. It pops and acts like it going to run on second or third pull. Take the choke halfway off then and it starts a runs on the next pull. It’s a long shot but I’d throw a spark plug in it.
Thanks for the suggestions! I'll try them.
   / Stihl 261cm hard starting #8
I have had to tweek the choke linkage a bit because the choke plate was not closing all the way.
   / Stihl 261cm hard starting #9
unclogged lol
   / Stihl 261cm hard starting #10
Have you checked your spark plug?
My 261CM starts on the 2nd or 3rd pull. The only time it didn't start the fuel solenoid had failed. My solenoid was a black colored one, it was original. As I understand there are only green and white ones available. I replaced mine with a green and it worked just like new. Depending on the serial number of your saw it could either take a green or a white one.
