MrFixit
Since new my KAMA 354C would on occasion be hard to put into gear (any gear, forward revers, hi/Lo ...) The gears would grind as if clutch was not fully disengaging. This only happened on occasion and when it would happen I would notice a rattling sound as soon as I pressed the clutch in. If I heard the Rattle, I knew the gears would grind while trying to put it into gear. Further pressing of clutch pedal to disengage PTO stops the rattle and gears shift smoothly.
The rattling is not the typical Automotive Clutch Squeal of a Thrust Bearing (Throw-Out). It's more the sound of a shaft spinning without any load on it and it vibrates. I'm 80% deaf and can't rely on my ears anyway! The clutch pedal has about 1 inch play before it starts to activate pressure plate springs. The visible holes in Thrust bearing have been lubed but no further adjustments have been made or gaps checked.
Lately the rattle has happened more often and I even noticed it happen as I was sitting still, in gear with clutch depressed (First Stage) and shutting engine off. As the Engine slowed to a halt It seemed as if the rattle continued for about 1/4 to 1/2 second after engine completely stopped. I'm not 100% sure this actually happened but it sure sounded that way to my deaf ears.
Any ideas as to what may be causing this rattle and gear grinding would be appreciated as I sure don't want to damage anything by ignoring it any further.
