Strecthed drive chain - remove a link?
   / Strecthed drive chain - remove a link? #1
marks
San Luis Obispo, CA
JD 870
After some heavy usage with my DR mower, the #40 drive chain has stretched beyond the capacity of adjusting. Fort the next two months I anticipate further usage in heavy brush on steep terrain, is there a possible concern in just removing a link from the chain?
Thx
   / Strecthed drive chain - remove a link? #2
I don't think it would be a problem. Hose reels on fuel trucks use a chain driven system and I have often shortened the chains when they get loose due to chain and gear wear. When and if you do shorten it, you can get full and 1/2 link's. Pick up some of each so you can get it adjusted as close as possible. TSC usually has a good selection of chain master links.
   / Strecthed drive chain - remove a link? #3
Check the sprocket fit of the chain. If the chain is loose after a only a few teeth on the larger sprocket it should be replaced unless it is a slow moving chain. A slow chain is very forgiving. A fast one should fit the sprockets well. A worn chain wears spockets and thereby shortens the life of chains replaced without a simultaneous sprocket change. A slow chain can literally be run until the sprocket slips. Not a fast one!
Larry
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
