40_acre_mule
I have about 6-7 acres of swamp on my place. I get buried in mud on a regular basis. If the 4WD and the FEL can't get me out, here's what I do..
Take a 2x6 about 8-10 ft long.
Chain one end to the left rear tire.
Chain the other end to the right rear tire.
Put the tractor in low and drive over the board.
The board acts like the paddle on a paddlewheel boat.
BE VERY CAREFUL. Once you drive over the board, it will come up and hit the tractor if you go too far.
You may have to reposition the board and drive over it several times before you get to solid ground, but it works very well. It will even lift my tractor with the 6ft bushog attached.
I have driven through some stuff I couldn't even walk through on foot using this method.
I keep two pieces of chain just the right length with hooks attached to both ends and a board about 3 feet wider than my tractor for just this purpose.
P.S. This method will usually cause a coating of mud to cover the operator.
