Buckgnarly
Platinum Member
They ALL suck a battery down quick if you do alot of lifting and angling. Unless you have a aux. belt driven pump powering the rig. Fortunatally, the only time I ever killed my battery in my plow rig was when I left it in float after I was done plowing. Left the A-coil energized and I had the plow controls wired to 12v hot-at-all-times. It wasnt until 3 or 4 days later when I needed the truck again. And yep, dead. On my new rig, I tied the controls to hot-in-run-only power. So it wont happen again:mur:
So does that mean it works now? What was the issue you think? A new C-solenoid WITH coil is only $78
I am thinking it was the 3 wire harness, possibly an internal short. I religiously use dielectric grease (actually still have a HUGE tube of it I "acquired" from the Air Force while in the Army...heh-heh) so I am guessing it was intenal on the plastic connector end. I used new male and female bullet connectors so no more 3 wire connector, now each has it's own seperate circuit/ run.
Unfortunately broke that stud, so simply tacked it back on. All works now, just waiting on the white stuff.
