Ricn
- Joined
- Sep 18, 2015
- Messages
- 446
- Location
- WA
- Tractor
- Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
Owning two very old tractors and one old crawler, I have thought of buying a sub compact to be used for small jobs, moving dirt or just anything I need moved within the bucket lift limits of course! Besides hauling, I'll do some field mowing in tight spaces around trees, along fences, buildings, gardens etc. using a 48 inch brush hog and also a PTO log splitter for all my wood needs. The small units look to be ok for my use but are just to small for comfort considering my large frame and height. Have only sat on two, the Kubota 2370 my neighbor owns and also the small Kioti, forgot the model number. JD makes small units that I haven't looked at yet or the NH Boomer series. The Kioti guys showed me a larger Kioti model CK2510 that fit me pretty well and after looking it over, noticed it is much like a larger tractor having what looked like a bell housing where the little Kubota and smaller Kioti was put together in like two pieces. The three units I speak off all have forward reverse pedal so are hydro I believe. The Kioti dealer told me that small tractors, those made in what I'll call a "split configuration" are good for light work but don't break one, as their repair costs are high. The heavier made Kioti and perhaps Kubota has one its equal, looks to be what I want but my big question right now is, will the CK2510 really hold up running for maybe 3-5 hours each use? I liked this tractor from its looks and from the seat space but then I haven't checked everything about it; looking is often dangerous, much like when looking at new trucks, we don't see the small things that become a nightmare latter on so need to do my homework if getting real interested. My JD's after 50 plus years are still running so I wonder now will these South Korean or Japanese units be doing the same? Kubota owners for the most part, rave about their little tractors as does my neighbor but this CK2510 weighing in at 2200 + pounds looks like the tough guy on the block, but is it as durable machine as it looks? There is cast iron made in Asia then there is cast iron much like my old JD's but are they equal in strength? Many small tractors I read have aluminum and plastic but this Kioti in question looked to be mostly Cast but with plastic hood and metal fenders? The dealer also sells Mahindra and Massey I believe. - Anyone here have one of these CK2510 Kioti tractors and how is yours holding up? What would be a comparable unit from Kubota? I'd like to here from owners if possible concerning this.
Thanks for the responses. - Ricn
