DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,227
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
It does sound like a float issue. May be stuck, need readjusted, or, they can even get a pinhole in the solder joint, causing them to sink. If and when you tear it apart, shake the float and check for gas inside.
You may get by with just tapping the side of the bowl and jarring it loose, but then it may be doing it again pretty quick. Not saying there may be speck of something holding the needle valve open.
When you tear it down, be sure to remove the el, where the fuel line attaches. There is supposed to be a filter screen attached to that el. If it is damaged, or gone, it may be letting specks of rust, or dirt into the carb. causing float/needle valve problems.
