SS isn't able to be engaged/disengaged.
The 4wd lever is below the seat to the left. When the tractor is turned with 4wd engaged there is a "de-clutch" that automatically disengages the 4wd for safety purposes. If you still wish to have 4wd capability while turning,the lever on the pod top must be used to override the "de-clutch".
Do I have you confused yet?
Yes, thank you very much:confused2:
So I have to override the default 4wd behavior there is a lever below the seat to the left.
That means the only machine item related to SS would be the FEL moving when the wheels are moved into the "super steer" position, meaning run all the way to the stop in either direction. Is that right?
Also, given the hilly terrain that I have, should my default be to over-ride the "de-clutching" behavior? How might this get me in trouble?
Keith
