JoeL4330
Platinum Member
snow plow control?
Thanks for the links guys. Looking at this I realized a 4 pole double throw is NOT what I need. I'm looking to combine four functions into a single switch, like a toggle joystick. So I can have up/down and left/right available on the same switch by moving the switch in any of four directions.
Now I'm not sure exactly what I need. I'm thinking I need perhaps 6 poles. Two poles for voltage input (12v hot and ground). Then another 4 poles for control of each of the two motors. Am I on the right track with this? :confused2:
You are not going to find this type of operation in a standard toggle. Either go with a joystick as others have suggested or seperate switches.
What about going with a retro joystick from a video game? Would have to hook up some relays to increase current ratings, but if they had 4 micro switches mounted in the base it should work. You could also look at the joystick from a honda 928 snowblower. I have this blower and it uses a joystick form the chute and damper. or maybe this?
Joystick 4-way toggle switch, Industrial/Medical UNUSED - eBay (item 280631341427 end time Feb-23-11 14:42:29 PST)
