kmaz
Bronze Member
About a month or so ago my robin 25 with 560 hrs died.... aside from the hard starts in winter every problem it gave me was in the rocker/lifter area, this one was no different. Upon disassembly I found the valve guide on the exhaust valve starter side of motor literally cracked in half. Must of gotten loose I suspect from a heat related issue. Valve guides can still be found but it had wobbled around and widened the sleeve. I've had it with the robin so ordered a kohler ch730-3004. Installation was fairly straightforward. Only other new part I ordered for motor was new pt exhaust and a new lovejoy rubber spider thingy.( mine was a little worn.)
You can imagine my disappointment when all done couldn't get it to fire!! No spark!
Searched the forum but couldn't fine anything on wiring from robin to kohler.
Terry saved the day today. For others that may make the switch, on the pt harness there are 4 prongs with red, black, green, and blue.
Black is center top. Red is on one side by itself, and green and blue is on the other. Simply switch the green and blue wires on the connector. Green where the blue was and blue where the green was.
Sure enough...fired right up!
Thanks terry!
Kris
Thanks terry!
Kris
