Something is not right here, I used to be able to flip the shackles back on my Toyota landcruiser without having to take the weight off it.
I presume each axle has its own set of springs, if so, for the rear to be off the ground then the front axle is the culprit.
Check that the shackles on the front springs are angled away from the axle, eg, if the shackles are at the front end of the springs then the shackle plates must be angled forward.
If a shackle has flipped over, this locks the spring so it cant move plus it forces the spring into an over-arch position, the ends of the spring leaves have normally moved away from the next leaf. This in turn lifts the body of the vehicle higher than its normal ride height and this could be why your rear axle is off the ground.
Worth checking anyway.
cheers
roscoe
