Sigarms
Super Member
In the winter I bump them up to about 140 and in the summer I drop them to 120.
You seem to forget this conversation we a couple of years ago. Unless you put in new water heaters recently and bought the commercial controller to set the temperature setting higher than most residential applications, I'll assume you still have the same commercial water heaters that were installed more than a couple of years ago?I just turned them up to show where they can be set
I should correct myself as well. It is not impossible to set higher water temperature settings on some residential water heaters, however, considering the fact that in less than 5 seconds you can get major burns that require hospitalization at 140 degree water temp, it does seem kind of dumb that you would do so. On the current Rinnai models, residential models can go no higher than 120 degrees with the MC-91 controller. At least that is the information they gave me last year when when I was at their US facility in Georgia.
And that is one reason why some people don't actually save money.Also feel that children can be taught to not take a 3 hr shower or waste hot water
The advantage to a tankless system is that is heats water only when you need it. Four people taking a shower in the morning learn (or are told) to minimize the amount of time in hot water because you may run out of hot water. Take those same four people and instead of taking a 5 minute hot shower, make it a 15 minute shower, and multiply that by the days in the year, and you're gas usage may actually go up.
One of the most important factors in figuring the right size unit isn't the amount of people taking a shower (even at the same time), but the possible maximum flow rate at one time. Exceed the flow rate and add the temperature rise into account, and I know more than a couple of people who were not happy with a undersized tankless system. More than one occasion I had to measure the flow of a tub or shower with gallon buckets because a homeowner wasn't happy with their tankless heater.
That said, odds are, two or three people will be fine with a standard tankless model.
