Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
have_blue said:I hate when that happens.
Some day tractors will have a steel frame and modular parts. They're built from big fragile castings for no other reason than tradition.
I wouldn't call them particularly fragile. Tractors were primarilly designed as farm implements.. not bull dozers and track hoes.
Take a look at an industrial tractor.. or a farm tractor that has an industrial equivalent. Lotsa reinforcement.. usally better fornt axle.. and things like laodersa and hoe's have huge underbelly sub frames.. generally interconnected.. etc.
Modular? You mean like having a seperate front steering pedistal or axle, seperate engine casting, a seperate tranny casting, a seperate steering gear casting, a seperate center section/hyds, and a rear end casting, with removable axle trumpets??
How much more modular you want them... they are already just a big line of bolt together sections.. each one an assembly by itself... and in many cases thru history.. very interchangeable.
A 9n rear end will fit on an 8n, or 2n, and i believe a fergy 20/30. i know a fergy 30 rear end will fit an 8n. 9n 2n 8n trannies all will bolt up to either rear end or engine flywheels.. .. thats interchangeability from 1939-1952, and cross manufacturer.
Jump tot he hundred series. most of the 4spds/5sps/ can be swapped with their respective counterparts up between the x00 and x01 series. You can intermix the trannies.. sometimes with only minor things like changing a flywheel.. etc.. in the case of dropping an x6x trranny into a x4x chassie.
Lotsa ford x-7/8-1 tractors that came from the factory with 10spd sos trannies.. that now have a 4 or 5 speed in them..
Steel frames? Lotsa tractors had steel frame rails.. look at AC and JD just to name 2...
Soundguy
