Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
No, actually I did not know that. The only experience I have had with water and oil was crankcase oil. In that case you can see them separate on the dip stick if you know what to look for. I did not know they would go to solution when it's trans oil. thank you.
Not soloution... oil emulsifies in water, sans addition of a polar solvent..
Soloution involves disolving a material.
suspensions is suspending a materila.
all different.
Now.. you can add a polar solvent to oil, and it can solvate some water..
things like transtune by seafoam is a dewatering agent for trans / hyd sumps, and it does exactly that.
for instance.. rubbing alcohol is a polar solvent.. water is polar.. as a neat test take a test tub half full of gas.. put in 2 drops of water.. see it set clearly sefined at the bottom.. fill 90% tot he top with 90% rubbing alcohol.. now agitate.. where's the water go? ( nowhere.. still there.. just all broken up! )
soundguy
