JDgreen227
Super Member
My JD has original front tires, turf tread on a 14 inch rim...and although the tread is fine on both, one of them has a slow leak in the tread right inside the outer tread edge...the tire has not been punctured but is leaking because of a thin spot in the carcass, I have put two plugs in the area but it still leaks about 1 -2 psi per hour. I have never used any type of tire sealant but am considering using it to stop the leak rather than take it to a shop for dismounting and a patch on the inside. The label on Slime brand sealant says the sealant remains liquid and I would try using it, but what if it doesn't stop the leak, would the stuff cause any complications? Thanks for any input and advice.
