junkyardwarrior
I am going to put a three way switch on the seat circuit today. I want to try wiring it where the switch will let me run it with it active and then switch it to a bypasss if it starts doing it, so I can see if that is the switch causing the problem. I have a wiring loom made that I can connect to the plug and move to another switch if that isn't the one. Wish me luck.
Raise the seat, and just to the right of center there is the main wiring harness. The harness has a big white plastic connector with a bunch of wires all connected at one place. Check the wires in the connector. Some of them didn't have the wires pushed into the connector far enough and while running would vibrate and "disconnect" briefly, so fast that you couldn't hear it unless you were listening. Not to say that IS your issue, but just stating what I've seen in the past.
