jdbower said:DO you have an implement attached? If not, you can tighten the turnbuckles to fix the issue. You may also find that the arms don't rub if you raise or lower them. My chipper is a tight fit but doesn't rub when I've got it raised, other implements are fine.
jdbower said:The iMatch comment reminds me, if you add iMatch or something like Pat's EZ Change it will also push the implement back a bit further and may increase the clearance a bit.
Is your ballast box iMatch-compatible or is it a custom box? If it's custom, any chance you can reduce the distance between the attachment points?
T185 said:Had the dealer reverse the tires on my 2520 but I still notice the rear wheels are rubbing on the three point hitch
Does JD sell a rear spacer kit?
T185 said:Ballast box is from JD, I have a iMatch on order, should be in by the middle of this week. Hopefully that will fix my problem....
