Thanks for the ideas JJ.
It's amazing to me how this mystery has evolved over time... let's review:
I order a new TYM backhoe with my tractor and want a thumb on it. My dealer gets and installs a Wallenstein thumb on the backhoe which comes with a Salami spool valve for the thumb. Works fine for a while but then begins to leak from the spool. Dealer gets a replacement valve from Wallenstein which is an identical Salami valve. Shortly, it begins to leak from the spool. I then pull out the spool to find the o-rings damaged. Each time I replace the o-rings only to have more leaking in short order and more damaged o-rings.
My dealer then installs a Prince RD4100 spool valve which works great for many months with no leaking. He tells me when he delivers the replaced thumb valve that there will be an occasional screeching sound and there is. Sometimes when operating the thumb, there is a screeching sound (even if there is no load on the thumb)... not each time it's operated... just sometimes.
Then recently, the Prince RD4100 valve starts leaking through the PRV... not around the PRV but straight through the core and out the adjustment screw. Upon investigation, I find that this valve has a number of options including 2 different PRVs... 500-1500psi and 1500-3000psi. (I have not found any model# info on the valve yet so I can't determine which PRV is installed and my newly ordered gauge hasn't arrived so I can't check it that way yet).
I want to make sure I understand how the pressures and the PRVs are supposed to work before I start ordering a new one so I can get the proper one I need.
Let's say in theory my tractor is putting out 2200psi at the rear remotes. The two backhoe hoses are connected to the rear remotes. The backhoe valve presumably has a PRV and it's set at 2000psi (in theory) (NOTE: the BH itself has been operating fabulously with no problems). The thumb valve is connected to the BH valve (at power beyond port?) and the thumb valve has it's own PRV which we'll say is set to ?.
So if I understand how a PRV is supposed to work, the PRV limits the pressure going into a valve and any device connected to that valve (such as a backhoe cylinder) to prevent potential damage to the valve or device. So when the PRV activates, it merely bleeds off excess pressure fluid (which is returned to the tank)... the PRV itself is not supposed to leak OUTSIDE of the valve. So my leaking PRV is broken in some way and I need a new one or repair the one I have.
But does it seem like the pressure is set too high or two low on the different thumb valve's PRVs? Blown o-rings in the Salami valves originally might seem like pressure set too high? The screeching of the new thumb valve might seem like pressure set to low?
Screeching on the new valve seems like maybe the 500-1500psi PRV is installed (factory default setting of 1000psi). Just wondering which PRV option to try an order.
Ohhh... and there's a third option on the Prince RD4100 valve which is a simple plug - no PRV at all. The thumb cylinder is a 2 1/4 size so if there was no PRV, then the BH valve PRV would be limiting the pressure to 2000psi?
Then there's ordering the parts themselves... haven't found any websites yet that list these PRV options... sigh.
Thanks for listening to me ramble!!
