cager
I've got a Cub 2554 (2005 model year) with 325 hours. While mowing this past Saturday...the right front tie rod came apart from the ball joint assembly. I guess it simply wore out. I tried inserting the ball joint into the assembly but to no avail. Of course, with the tie rod not connected...there is no steering. My first frustration: I had just started mowing my 1.5 acres of grass. My second frustration: None of the nearby Cub dealerships or any other tractor dealers for that matter were open on a Saturday afternoon. Figuring a dealership wouldn't have this particular part on hand, I ordered the parts on-line Sat night. Today, out of curisoty, I called my local Cub dealer today and they had several of these ball joint assembly's in stock. So I picked one up. When the mail order arrives, I'll have a couple for inventory.
Here's my questions for those who might have some insight:
1. Is 325 hours par for the course for these ball joint assemblys?
2. Should I replace all four of these ball joints while at it or just replace as they wear out?
3. Will I need to check the front wheel "toe" after replacing a ball joint assembly?
Apart from a belt or two, routine maintenance and replacing a couple deck wheel axels, this machine has and continues to be a work horse. Thanks for your input.
