Bluegill2
Veteran Member
- Joined
- Jan 21, 2012
- Messages
- 1,870
- Location
- Success Missouri
- Tractor
- Kubota L3800DT, L3750DT Shuttle
When I got my first tractor, I also knew little about how to properly use it, and I knew
noone who could show me. I made a bunch of mistakes.
Now we have forums like TBN where lots of folks volunteer to help.
Just a couple of things off the bat: you always have to have ballast on the 3-pt hitch when operating the loader. Your owner's manual usually says you should not even INSTALL the FEL without ballast. I did not get an OM with my first tractor. :-(
You almost always want to be in the lowest gear range when using the FEL. Higher
range than that and you can stall the engine, or burn the clutch. A properly-
driven tractor's clutch should last 1000s of hours.
For stability, you want to widen your rear wheel track to the widest setting, if you
have AG tires. Stay in 4WD all the time, unless you have pavement. You have
no front brakes.
Don't give up. The L3130 is a great tractor.
OP, read the above again, especially the bold parts. A loader is useless on this size tractor without rear ballast on the 3 pt hitch!
I don't really agree with the stay in 4wd all the time, but in this case it's probably wise.
Slow down on the rough ground! Get a box blade to smooth everything out! Have the clutch in, or out, don't ride it! Have the rear tires filled, if they aren't already.
If you are not enjoying using the tractor, you may not be the type of person to own a tractor...
