The valve guides on a ford 172 are press fit and cheap. About 4 bucks each. If you have a press, it's a pretty quick job to swap in some.
John-bud, you might very well be correct on this one. The I&T manual I've been using is a little unclear. According to Paragraph 90, "Intake and exhaust valve guides are interchangeable only on non-diesel models and can be pressed from cylinder head if renewal is required."
On the other hand, the valve seats may be a different story. Paragraph 89 states, "Exhaust valves are equipped with free type rotators shown in Fig. F071 and, except on 144 cu in diesel engines, the valves seat on renewable type seat inserts which are shrink fit in the cylinder head. Intake valves and, on 144 cu in diesel engines, the exhaust valves seat directly on the cylinder head."
If I understand these paragraphs correct, both the exhaust and intake valves seat directly on the head for the 144 cu in diesel, but on the 172 cu in, the exhaust valves (but still not the intake) sit on renewable seats. Moreover, valves guides appear not to be interchangeable on any of the diesels engines. Seems to me that it would then be very difficult to remove the exhaust seats from the bottom of the head, while leaving intact the valve guides on the top of the head.
Perhaps I haven't looked carefully enough, but I wasn't able to see any obvious seams for the valve guides. However, the seats do seem renewable
. Adding to the confusion Restoration Supply company does indeed sell intake and exhaust valve guides $3-4 each . . . .
Does anyone understand this? Maybe someone out there with the ford shop manual can help me (us) out?
Pete
