VroomVroom
Veteran Member
- Joined
- Apr 30, 2010
- Messages
- 1,092
- Location
- Newfoundland
- Tractor
- Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Excellent job. He must be pretty happy with that result.
Next time around as an FYI I'll bet you could probably chop up that bush if you do it a little bit at a time. Tillers are pretty tough.
The man just brush hogged the day before so I assumed he wanted to keep them. However, I think the tiller is a brute but I would be hesitant to mulch up a bush. Something I could look into.
I have done really abusive things with tillers over the years--it started gradually and I figured to kept on keeping on until I had a problem. Never did. With my lighter duty Howard tiller I even moved 400 ft of gravel driveway with base of bigger rocks and all. Tilled it up and moved it with no probs.
Even now I have a heavier tiller but I often till up--slowly--4" stumps and if I'm doing drainage or construction work often till over whatever debris is there and that includes old drainage tiles, culverts, trash dumps, etc. It's not always at full rpm and it's often just skimming they surface but it works. Just my two cents here.
Thank you.
Pray hard... I need a miracle.
Not looking hopeful...
God Bless all of you.
David
