mustangsallysdad
Platinum Member
- Joined
- Jan 16, 2010
- Messages
- 559
2010 Ford Explorer can tow up to 7,115 lbs. V6 versions are available that tow in excess of 5,000 lbs.
2010 Ford Ranger can tow up to 5,940 lbs.
You must have the only one with a 4.3. Trailblazers, 02 and later Bravadas, and Envoys were only available with a 4.2 L6, a 4.8 and 6.0 V8 [SS package]. The 4.3 V6 was offered in the S chassis SUV up until 2001, after that the switch was made to the Trailblazer and the 4.2 was the standard engine.
There's no database of Tow Ratings since that is a number made up by the manufacturer which has NO legal binding whatsoever. The only LEGAL numbers are the GVWR's, GAWR's and GCWR's, the GVWR must be listed on the vehicle/trailer. The "database" is probably a list of GCWR's since that is what matters and not the "tow capacity". Tow capacity is simply the vehicles actual weight subtracted from the GCWR.On one truck forum (and I don't remember where) there was talk of a data base the state troopers use to determine if your (for example) 1999 Ram 3500 is rated for 10000 lbs or 12000 lbs.
Does anyone know where the complete database is if it exists?
Most of the doorplates I've seen only have GVWR's and GAWR's.
I realize I'm reviving a year old thread, but this forum usually comes thru with the answer without a LOT of flames and bickering.
As Bird wrote there are almost endless variations on equipment so it's hard to figure how much something CAN tow versus what it's rated for.
I've got the trailer life ratings from 1999 to 2008, so I'm good there, but I'm also looking for older ratings.
