jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,393
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I have owned three Rotary Cutters operated behind two different Kubotas.
Standard grade King Kutter 48" R/C, L-48-40-P (428 pounds) behind Kubota B3300 SU. Purchased used.
Land Pride 60" R/C, RCF 2060 (620 pounds) behind Kubota L3560. Purchased new.
Land Pride 60" R/C RCR 2660 (1,002 pounds) behind Kubota L3560. Purchased new.
The well worn, relatively light King Kutter drive shaft was usually fairly easy to connect to the tractor. I lubed the PTO fittings with lithium grease, applied thinly then lightly wiped off with a rag.
The two heavier, wider, Land Pride R/Cs, purchased new, were more difficult to connect. I experimented with several different lubes on the PTO fittings, first a very light coat of lithium grease, then WD-40, then Fluid Film, then three brands of "dry lubricant" and now Blaster (brand) garage door lube, which works best for me.
I have a standard mounting technique. I make the single Top Link connection first. Then I make the two Lower Link connections, adjusting the Top Link if necessary to assist aligning the Lower Link bullseyes and the implement draft pins. Then I raise the R/C until the PTO drive shaft is level with the tractor splines, then simultaneously pull back on the lock collar while sliding the shaft on until connection "clicks".
Lube seems a critical factor to me. Following is my experience in warm Florida. Your experience may differ.
1) Lithium Grease is too thick. Unless wiped off after application, tends to collect at front of shaft collar, preventing final 1/8" of travel needed to lock the shaft to the tractor splines. Attracts and holds dirt and dust, even when wiped off with a rag, so grease coat is very thin.
2) WD-40 works pretty fair making connection but burns off during R/C use, making removal of dry PTO shaft difficult while connection is hot. I never had the patience to let connection cool.
3) Fluid Film worked better but held dirt and dust a little. Best applied thinly.
3) Dry lubes consistently better. I experimented with wax based bicycle chain lube, Home Depot "HDX" brand spray dry lube and Blaster brand spray Dry Lube. All about equal. No dirt retention.
4) One day I was out of spray dry lube and decided to try Blaster brand Garage Door Lube which was on my bench. I like this best. Can says: "64742-48-9 Hydrocarbon Solvent, 68849-42-3 Anti-Wear Additive". This product seems to leave a tiny amount more lube residue on the connection, providing best-so-far slip lubricity.
The wild card is wear, especially wear in the female PTO fitting. After considerable use does this female fitting wear in and make PTO connection easier? I do not know.
I keep a rubber cap over tractor PTO splines when implement not connected, to guard against sap, dirt and dust accumulation.
I value other's experience which will often vary from mine.
