bostractor
Occasionally, I'll have problems getting my transmission to shift to low. It'll go into medium and High easily. Any insights on this? Thanks.
Sounds like the gears just need to align. Press the brake and clutch, then shift into neutral, let out on the clutch work the hyrdo pedal then clutch it and it should go into low if not you may have to repeat.
I depress the clutch all the way, then slightly press on the HST while pushing the range lever into low. The odds of hitting a tooth vs a slot are greater when going into low. You just need to spin the gears slightly to get a space to align.
