ford cyl thread kits are available from Snap on, mac tools etc. I have repaired them with the Helicoil steel insert kits also. If using the Helicoil spark plug insert kit, the cutting tap must be modified to use in the deep, limited accesss plug hole. I welded a socket to the tap so I could use a locking extension on it. Move the piston on the affected hole so both valves close. Grease the tap flutes heavily to catch chips as the tap cuts the hole bigger and rethreads it. Use a long air nozzle inside the cylinder to blow chips out the hole. Install your threaded solid insert and off you go. There are Youtube demos of the official tool kit install too. It is basically the same except the kit is much more high tech and more likely to have a successful outcome if used properly. The inside out taps are for cleaning damaged or cross threaded holes, not installing inserts.
