Briggs has only one engine I would even remotely consider, that is the Vanguard which is their top of the line engine. (I just learned on the CC forum here at TBN it is made for Briggs by Diahatsu.) The I/C and Intek are virtually identical engines, and Kohler created their cheaper Courage lineup to use on entry level machines much in the same way Briggs does with the Inteks. None of the under $2000 machines will get a decent Kohler Command any longer. Most of the top end over $2k tractors will likely get Kohler Command, Briggs Vanguard, Kawasaki, or Honda power.
The average lifespan of the small lawn tractors is around 400-500 hours, so tractor makers wanted more economy minded engines for those smaller models to keep the costs down, hense the Kohler Courage and Briggs Intek 750 hour engines. Command, Vanguard, Honda and Kawi are rated for 2000 hours, and are more expensive to manufacture.
-Fordlords-
-Fordlords-
