LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 10,784
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
I'm not sure what your asking;
the throttle lever is mounted off the steering column, push left to throttle down, pull right to get full throttle.
Many of the older diesels had mechanical fuel stops some where on the throttles, many had a pull cable to stop,
some had a cable operated stop with a start position just up from the stop for the start then all the way up for the run.
The most confusing I can recall on those old IH's was the starter push button and the ether start aid push button, both black rubber covered buttons,
used to pull the ether bottles off because some not familiar with them would be pressing the button several times you could the ether cans spritzing into the manifold.
