NTG
I just bought a 2016 New Holland Workmaster 33. It is a diesel and has the tier 4b final exhaust deal on it. I'm reading my manual and it says I need 15W-40 DPF compatible CJ-4 oil. According to the manual, New Holland's is "Ambra Mastergold HSP engine oil SAE 15W-40". Does Walmart sell anything like this or am I going to have to go to my dealer to buy this? As long as it's marked CJ-4 15W-40, is it ok?
Also, the manual says it uses 50/50 ethylene glycol and water for coolant. Is that the regular 50/50 coolant I can buy at Walmart? The manual says I can use regular ethylene glycol or drain that and swap it to the OAT coolant. When the tractor is ready for the first coolant change, should I swap it out? And can you buy OAT coolant at Walmart or Autozone somewhere like that, or will I have to get that from my dealer as well?
I'm thinking that if I have to go to the dealer for all this, I'll order a couple cases along with maybe 3 air filters so I have everything in stock when it gets time to change things as my dealer is over an hour away. Thanks.
Oh yeah, I haven't found anywhere in the manual where it gives a number for the oil filter. Can I just get the number off the filter and buy a matching one at Walmart, or does that have to be from the dealer also?
And last question..... sorry, I'm trying to remember things as I go...... Do I need to add a diesel additive in my fuel to clean my injectors, or is that not necessary? If so, is that an all the time thing, or just an "every so many fillups" kind of thing?
