dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,182
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
A proportional flow out put, requires a pressure compensation system.
Compensation will depend on load pressure and supply pressure, which is above what we are dealing with here I assume...
And now, I also got confused what your common definition of "feather" the valve means??
You are certainly correct that proportional control is way beyond what we
need to deal with on TBN. But definitely interesting.
Good point on "feathering". I use quotation marks because it is not a term I
have seen in technical docs on hydraulics. What I think TBN members
usually mean is that it is a partial movement of a spool valve control lever
that does not allow full flow to the work ports. Most of the discussions here
seem to involve how to use 2 different valves simultaneously with a one-
pump backhoe attachment. These are the kinds of hoes most of us have.
For me, I try to operate 2 valves right around their cutoff point, with some
(though limited) success.
