joshuabardwell
Elite Member
I just watched this video.
I was surprised to hear him say that, in general, a low OCV is more desirable. I have heard that a higher OCV is needed to run 6010 properly. Maybe this is a case of "Goldilocks"--not too little, not too much, but just right? The other thing that surprised me was that a higher OCV is conducive to sticking the electrode and snuffing the arc when short-arcing, whereas a low OCV is more conducive to "digging" and keeping the arc going. This just seems backwards, since I would think high voltage = more energy.
Thinking about the second point: I = P / V. If 40 in gear 2 and 70 in gear 1 produce the same current output, then:
I = P2 / 40 = P1 / 70
P2 / 40 = P1 / 70
P2 / P1 = 70 / 40
P2 / P1 = 1.75
This 1.75 number is not actually correct, since 70 and 40 are not actually voltage values, but are an arbitrary representation of voltage on a 1-100 scale. Nevertheless... 40-in-gear-2 produces more power (heat / watts) at the same current (amperage) than 70-in-gear-1. This helps explain why the arc is harder to snuff, but then why does the lower-voltage setting produce a faster-solidifying puddle? It seems like putting more heat into the puddle would cause the puddle to be more liquid, not less.
Can anybody help me make sense of this?
P2 / 40 = P1 / 70
P2 / P1 = 70 / 40
P2 / P1 = 1.75
