I agree that no one would intentionally offer bad advice. Yes, we can all read the manufacturer's specs but plenty of people do not look at them closely so that is why I tried to emphasize the differences between the two machines. There are a lot of differences between the "42's" (like the direct drive versus indirect drive to get more rotor RPM for the shredder). There seem to be quite a few members on this site that have the BXS42 but very few members with the BXM42. I just don't want assumptions to be made that the two machines are almost identical. The best that the original poster (and myself) could hope for is to get some feedback from someone who has been running a BXM42.
I put the BXM42 on my B3030 today but have not had a chance to run it. So far, here are my findings:
1. The PTO is a little long and may need to be shortened--not a big deal, the manufacturer recommends doing that if necessary. I just don't want to cut it unless I have to--I will tinker with it a little more.
2. The angle of the PTO shaft appears to be at a really bad angle since the BXM42 input shaft is pretty high up on the
chipper/shredder. It appears to be necessary because of the positioning of the indirect drive. Since my tractor is a compact tractor, the PTO is lower than it would be on a bigger tractor. First impression is that the BXM42 would be a better fit for a bigger tractor. Maybe not an issue for a BXS42, I will see if I can find some dimensions between the two machines and compare. Is that okay with you Gus?
