Chilly807
Elite Member
Personally I'd feel safer without the remote. Last thing I'd want is for the winch to engage accidentally while I'm hooking a choker. You only get one set of fingers.
Norse (Igland) also offers a wireless remote option, I have no idea how much it is since I bought my winch used. Like the other guys, an auto-release snatch block is high on my list of want-to-have items. I use a snatch block whenever the hauling path is either crooked or I can't get a straight pull from the back of the tractor. Norse allows you up to 30* angle, but I've had a couple of occasions when the outside wheels came off the ground even at 30* or less.
The newer style winches with the blade as opposed to 2 feet are a lot better.. you set the top link to have the winch angle from 10-15* backwards when the blade is touching the ground and lower the 3 point control all the way. If you get hooked up solid, the angle tends to force the blade further into the ground the harder it pulls. If you have as close to a straight pull as possible, it would be very difficult to flip the tractor over backwards, if it's even possible.
Sean
Sean
