3 Sisters Ranch
Just a couple of thoughts on riding surface materials - been through the same dilemma -
shredded tires - use caution with shredded tires due to the steel belts used in tires, a lot of rubber riding surfaces in arenas are ground up old tennis shoes
manure - only if you like flies - would strongly recommend you not use manure.
washed sand - sand is as good for the $$ As you can get IMHO. Just keep in mind there are generally two types one is sand that the grains are round and the other has edges both act differently and provide different support values. Keep in mind sand if ridden on a lot will break down into dust.
sand - best to use washed sand as unwashed will have clay/dirt and defeats the purpose of sand.
wood shavings/course saw dust - mix in a % of wood shavings is not a bad idea, BUT as you are aware no hardwood and do not over do it. The wood shavings do hold moisture well which will help keep the dust down when dampened, but the down side will be after a period of time and riding use they will decompose and will break down. So you'll have to add more with additional sand. Stay away from actual chips.
Our preference is sand with a bit of for sawdust from the local sawmill. We generally use fir as that is what is readily available to us and cheap - my little trailer holds about 10 cubic yards and runs me $ 10 to fill as we also use it in the stalls for bedding.
Good luck
Mike
I might as well ask what y'all think.[/QUOTE]
Good luck
Mike
