strum456
Platinum Member
It looks like you have done your homework. Perhaps you could make your own, but I am not a chemist and I really have no idea what the results would be. Shipped to your door, I believe the stuff I use is $24 per gallon. When improper paint prep could ruin an entire paint job, and problems might not start to apperar until after much time and cost has been spent, it is just not worth it in my opinion to experiment with such things.
One thing that I will add is that the waterborne wax and grease remove does get the surface cleaner than solvent based. However, solvent based is far superior for removing adhesives (masking tape, pin stripes, etc.). Ideally, you would use the solvent based first, and then the waterborne. You will notice everything the solvent based missed on your rag after using the waterborne. Also, solvent based cleaners cannot be used on many plastic bumpers. Waterborne is much safer on plastics.
