Hello I am trying to fix a "PTO popping out of gear" issue whereby the PTO will stop spinning as the lever kicks back to "off"
If I hold the PTO lever down it will stay engaged, but I can't seem to adjust the lever detents so that they will hold.
I am about to remove the linkage housing so I can have a look at the slip collar mechanism if anything is amiss.
Is there anything else worth checking before I do so? I do not think I have a dual stage clutch, and there is a strong spring holding the clutch in disengaged position so there is no way for me to introduce freeplay
