houser52
I wasn't sure the best place to ask this question but...
I'm switching my pin on loader to SSQA. I already have pin on pallet forks and have ordered a cut out SSQA plate to weld to the fork's frame.
The pin on brackets or part of them will have to be removed in order to weld on the plate and would like opinions about the best way to weld it on. The top of the plate can be welded directly to the the frame's round tubing at the top of the brackets. The fork's frame is 48" wide and the SSQA plate is 45"-46" so I can't held it directly to the sides of the frame.
I have thought about cutting the brackets even with sides of the fork's frame and welding the plate to what's left of the 4 remaining parts of the brackets. That would put the SSQA plate almost flush with the back of the fork's frame and keep the weight closer to the tractor.
I have also thought about cutting off that part of the brackets just below the pin holes following the existing angle of the bracket and welding on the plate at the same existing angle but that will put the weight out a few inches away from the tractor.
Or should I go a whole different route?
What are some thoughts from you all?
