Chilly807
Elite Member
Maybe I'm missing something. What would maintain the pressure in the line when the pump shut off if it was open on the end? And if the suction line was pressurized wouldn't it be a discharge line?
What's missing is what the OP is trying to do with the pump.. from what I read between the lines, he's either trying to boost the output pressure or installing a pumping station to get the water up to a higher level with enough pressure to still do it's job. High rise buildings are like this, there'll be a pumping "station" every so many floors to ensure the upper floor occupants still get decent water pressure, otherwise all the pressure is lost trying to get water up say 30 floors.
As to boosting the output pressure, if you have two pumps in series, the output pressure capacity of the second pump will be added to the feed pressure from the first. For example, 50 psi going into a pump capable of creating 50 psi as well will give you a possible 100 psi output before any efficiency losses.
One thing you have to be careful with is pipe sizing. For example, your feed piping (can be either pressure or suction feed) needs to be larger diameter than your discharge pipe. The "feed" pump must have higher GPM rating than your "boost" pump, or your pressure feed turns into a suction and you have cavitation troubles since the output rate of the first pump is not infinite.
Keep in mind that even a pump with a "suction" feed actually has a pressure feed of sorts, since the pressure the atmosphere exerts on the water entering the pump is greater than the low pressure the pump is creating ahead of it. The pump only creates flow, pressure is caused by restriction. A vacuum is defined as "lack of pressure".
Sean
