Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,135
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
Frst of all you are dealing with late1940's early 1950's technology in an MF50 engine. It's not the Space Shuttle or the F-22! So don't let that scare you.
You don't know the relief valve is stuck open. It could be a worn oil pump or worn bearings. In my opinion, however, the easiest thing to do is to check the relief valve. First spend the bucks to buy a factory manual for your tractor. At $100/shop hour, the book will pay for itself with the first repair you use it for. It will explain how the systems wok and if the repair job is too much for you to do, you can figure it out from the manual before you start something you can't finish.
I have no direct knowledge of the MF 50 but I am familiar with the Z series Continental engines that power them. They have a relief valve built into the oil pump and it has a relief valve that you can access once you remove the oil pan. Since I'm not familiar with the MF50, I can't say how easy the oil pan is to remove but it can't be that difficult. You drain it, remove the bolts, and remove it. The oil pump (a simple gear pump) is driven by the timing gears, The relief valve spring is held in place by cotter pin through the discharge passage. On top of that spring sits a small piston that fits the passage. You remove that cotter pin and the spring and piston should slide out. If the piston is stuck, you'll need to work around it with a small wire to free it and then get as much of the crud out as you can. The spring usually has a certain free length and some times the spring gets damaged. You can buy a new one and it should be cheap. When you clean the passage out you merely put the piston in, then the spring and then the cotter pin. While you have the pan off, you can buy some Plasti-Gauge and check the clearance on the main bearings. Compare them with the nominal clearance. If the clearances are above the allowables, you've found your problem. Now you have a decision to make. Replace the mains. If the mains are good, then replace the pan, fill with oil and see if the pressure is near normal. If it is, you've fixed the problem and you'll know the mains are good. If you still have low oil pressure, a pump replacement is in order.
