What is the trick to making leak free welds?
   / What is the trick to making leak free welds? #11
The tiniest bit of moisture, oil or back pressure can cause a pinhole. I welded a crack on a ripper frame on a cat and while it was cooling cracked open again because of the pressure build up inside the tubing.
I had a similar problem years ago while working on a RR freight car that had been sent in to the shop for repair.
A small short air brake line had broken off a welded flange that attached between two air brake valves. It was hard to get to, but I crawled in among the mess of pipes and other things in the way, and pushed the pipe back into place and welded it.
I hooked the air up and could hear a small leak. After soaping the area, I daubed the pinhole leak with more weld and cut the air back in. But, it still had a pinhole leak.
After 2 or 3 times of doing this, I was frustrated and mad and took the pipe completely off and put it on the table and welded it again. This time it was fixed, but I was always puzzled as to why it kept leaking every time I welded the pinhole while it was still on the car. I finally figured out that the valves on either side of the pipe had the air trapped in the pipe and must be causing a pinhole as the heated air was forcing its way out through the weld puddle.
   / What is the trick to making leak free welds? #12
Just think of all those welded pipeline joints that don't leak!
Course the welder has had courses, lots of practice and yearly competence checks.
There's a big difference between welding pipelines and welding hydraulic tubing. Hydraulic tubing is usually silver soldered and/or uses flared fittings.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
14ft. Deer Gate (A53424)
14ft. Deer Gate...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
MISC TOOLS (A55745)
MISC TOOLS (A55745)
Vin: R56AXDH43M1051134 (A55853)
Vin...
