Happy there are folks smarter than I here.
Soundguy, does the resistance always go up on a battery that goes bad? Or could it go down and draw all the current through that one path? (Showing my ignorance again.)
If the charger is designed right (equipped with current limiter or "soft" enough that the current will drop when loaded) it should survive short indefinitely. Since that is relatively easy to do I would guess that most chargers would survive such abuse.
In the case of one bad battery the simple diode isolation scheme will prevent the good batteries from discharging but the good batteries will not be charging either. All the charging currant will pass through the low voltage bad battery. It is way better than having the good batteries discharged just be aware that one bad battery will prevent the others from receiving their maintenance charge.
