zkurtb
Bronze Member
I just picked up a used Woods 7500 backhoe. It has it's own tank and PTO pump, does not use the tractor fluids. As with all used items, I like to change the fluids along with checking the bolt torque, greasing, and so on.
For the fluids, the manual says there are several different recommended oil types:
SAE Hydraulic Transmission Fluid.................All Temperatures
Type "A" or "F" ATF..................................All Temperatures
SAE 30-30W...........................................90deg F and above
SAE 20-20W...........................................35-90deg F
SAE 10-10W...........................................35deg F and below
All temperature makes sense to me, although I doubt I'll use it in the dead of winter. And somehow Hydraulic based fluids -- either the SAE or one of the ATFs seems to make sense to me for use in a Hydraulic system, rather than motor oil.
I'd like to hear from the collective wisdom and experience of the TBN users on the fluid choices and which one they would use. What is the difference, if any between the SAE, the ATF-A, and the ATF-F Hyd fluids for an application like this? And how would those compare to motor oil?
Kurt
Kurt
