Kubota
Original price (USD): $15,008 (2011)
Kubota B3200 Engine:
Kubota 1.5L 4-cyl diesel
full engine details ...
Capacity:
Fuel: 8.1 gal [30.7 L]
Hydraulic system: 3.8 gal [14.4 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 1,655 lbs [750 kg]
Rear lift (at 24"/610mm): 1,300 lbs [589 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPMs: 540
Engine RPMs: 540@2600
Mid PTO: optional
Mid RPMs: 2500
Engine RPMs: 2500@2578
Dimensions & Tires:
Wheelbase: 65.6 inches [166 cm]
Weight: 1,764 lbs [800 kg]
Front tire: 7-12
Rear tire: 12.4-16
full dimensions and tires ...
Kubota B3200 attachments:
mowing deck
front-end loader
backhoe
all B3200 attachments ...
B3200 Serial Numbers:
- Serial numbers unknown -
Kubota B3200 Power:
Engine (gross): 32 hp [23.9 kW]
PTO (claimed): 23 hp [17.2 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: power
Brakes: wet disc
Cab: Two-post ROPS. Optional sunshade.
Hydraulics:
Type: open center
Capacity: 3.8 gal [14.4 L]
Valves: 0 to 2
Pump flow: 6.7 gpm [25.4 lpm]
Total flow: 9.7 gpm [36.7 lpm]
Steering flow: 3.2 gpm [12.1 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 14.2
40 (optional)
Battery:
Number: 1
Volts: 12
Page information:
Last update: January 23, 2011
Copyright: Copyright 2012 TractorData LLC
Contact:
Peter@TractorData.com
ohn Deere
Original price (USD): $15,000 (2009)
John Deere 4005 Engine:
Yanmar 2.0L 4-cyl diesel
Capacity:
Fuel: 8.5 gal [32.2 L]
Hydraulic system: 6.9 gal [26.1 L]
3-Point Hitch:
Rear Type: 1
Rear lift (at 24"/610mm): 2,020 lbs [916 kg]
Rear PTO: continuous
Rear RPMs: 540
Dimensions & Tires:
Wheelbase: 69 inches [175 cm]
Weight: 2954 to 3175 pounds
Front tire: 6.5-16
Rear tire: 14.9-24
4005 Serial Numbers:
2008: 000100
2009: 210001
how to read serial numbers...
John Deere 4005 Power:
Engine (gross): 41.9 hp [31.2 kW]
Engine: 37.9 hp [28.3 kW]
PTO (claimed): 35 hp [26.1 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD optional
Steering: hydrostatic power
Brakes: wet disc
Cab: ROPS. Canopy optional.
Hydraulics:
Type: open center
Capacity: 6.9 gal [26.1 L]
Pressure: 2262 psi [156.0 bar]
Valves: 2
Pump flow: 8.5 gpm [32.2 lpm]
Total flow: 13 gpm [49.2 lpm]
Steering flow: 4.5 gpm [17.0 lpm]
Electrical:
Ground: negative
Charging amps: 40
Battery:
Number: 1
Cold-cranking amps: 770
Volts: 12
Page information:
Last update: February 29, 2012
Contact:
