ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,499
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Superduper said:Thanks Ovrszd,
I think I will go ahead and just order the weights without soliciting input from dealer guys. I don't however, consider this a modification, as the weights are clearly specified in owners operational manual and they will be dealer parts, and optionable parts for this tractor. If anything, I consider this one of many variations of factory configuration depending upon how tractor is optioned. As far as overstressing the axles, I am not so concerned that 29hp will snap the axles. From what I can see, this is essentially the same tractor as the JD3720 (44hp) without the turbo. Even the weight is identical. From there, I surmise that the axles are in all probability the same in both configurations, for if the axles were more beefy, the tractor should at least weight a few pounds more. Since the 3720 has 50% more power, then the axle should be plenty beefy to handle the rather lighter power load.
Very good ideas. When Jeep people with 4 cylinder engines ask me if the stock axles are strong enough, I respond that the Jeep is also offered with a 6 cylinder that develops 30% more HP and torque. They handle that so they'll surely handle the 4cyl. Your example is the same way. I don't think you have any problem adding the wheel weights and I think you'll like the results.
