5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,791
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Hardleys require thick oil so they don't leak everywhere....
I've been using the Mobil 15w-40 extreme for about a year now. I just finished plowing and the temp was about 17 degrees. My tractor is kept in an equipment shed. When I start it in cold weather it turns right over and always starts in a few seconds. My oil pressure light might stay on for about 5 seconds at most? The viscosity index on the 15w-40 is 140. The 5w-40 is 150?
Comparing CK4 vs CJ4
You don’t really need to understand the chemistry to appreciate the benefits of CK4 vs CJ4. The new oils provide better oxidative stability, more aeration resistance, and enhanced shear stability. In fact, in order to meet the CK4 oil API standards, lubricants must prove themselves through two new tests: the CAT Aeration test and the Mack T13 test.
Additionally, CK4 oils provide better protection for engines than CJ4 oils. Using CK4 should increase the time between oil changes and improve fuel economy, as well, thanks to lower viscosity grades. You find familiar, common grades such as:
- 5W-30
- 5W-40
- 10W-30
- 15W-40
