RayCo
Veteran Member
- Joined
- Jul 24, 2005
- Messages
- 1,029
- Location
- Chester County, PA
- Tractor
- Kubota BX24, Case 580 Super L
that little tractor cant weigh more than 1500lbs. i would not hesitate to put that in the pickup bed of a 1-ton truck. my 1-ton 1997 chevy can take 1850lbs of tongue weight, as per the hitch. i could hang that tractor off my receiver, and be within spec. no matter where you put it on the trailer, the trailer axles are going to take some of the weight. you cannot seriously tell me that you believe that putting a bx tractor on the front of that trailer is going to "technically" --(or otherwise)--overload a 3/4 or 1 ton truck. the tractor does not need all the way to the extreme front of the trailer anyhow.
Actually, a BX weighs a little under 3,000 pounds with the loader and backhoe on, but the load in question doesn't much matter. This trailer design will quickly exceed the tongue capacity of a truck before the hauling capacity is exceeded.
--on a side note, that trailer is very poorly designed with the axles all the way to the back.
Yeah, it is an interesting design. I'm guessing it is that way because of wanting the axles under the dump area.
