The kid
Elite Member
- Joined
- Apr 25, 2012
- Messages
- 4,132
- Location
- Middle Tennessee
- Tractor
- 1965 135 gasser, 1967 135 diesel
Yes I did. Looks like the battery was low. I guess running the heater and all the lights is too much for it. I didn't have my battery charger over where the tractor is so I'll go over after and charge it and let it run for a while at high idle to charge it up fully. I had this same issue last year but that was because it was a 15 year old battery I had in it. I didn't even consider the battery because it is fairly new.
If you have a bit of time you can rejuvenate that tired battery. If it's a maitenance free battery with no holes or plugs visible, then the battery probably has dried out. Feel around on top of the battery till you feel six circles in a straight line lengthwise on the top. Peel back the plastic label. The plugs either pop out with a small screwdriver or actually unscrew and has a rubber O right to keep them from leaking.
If the battery is 15 years old then it probably needs replacement so a bit of experientation won't hurt. Open the plugs and look inside with a flashlight. Low to no water in one or more cells. A whitish color inside is a sign of a sulphated battery which coats the lead plates and greatly reduces charge capacity. I took two tired batteries what where main Free and brought them back to usable life. I was saving them to use on a new battery exchange. I saw a bunch of videos on Youtube where people took "epson salt" aka magnesium sulfate and distilled water and removed the sulfate from the batteries. To my suprise it worked on both batteries. Basically the salts react with the sulfate in the battery and converts it back to sulfuric acid and clears enough plates to bring a dying battery back to a usuable state. Google "how to fix a maintenance free battery" OR.. If you don't want to bother just buy another one.
