wh22366
Bronze Member
Hanging around garages as a kid I remembered seeing a little pencil-shaped device that filled with penetrating oil, got snapped on a zerk, and was tapped with a small ball peen until the oil was forced through the crud to free the grease joint. I bought one two years ago - search under "grease fitting rejuvenator" - to try on a frozen pin. I found it works good on fittings that haven't been frozen forever.
All the other suggestions listed are good - in fact I'm going to try RickB's idea about driving the pin out part way to reveal the plugged cross-drill on the bottom pivot pin of my 416 Cat. First I'm going to visit the dealer to see where the drill hole is on a new pin.
My friend up the road (equipment operator for 50+ years) left me his fix for the plugged pivot pin in a small brown bag. He told me to take out the zerk, clean out the hole, and drop one of these little cylinders into the hole. Then extend the two little wires on it to someplace behind something heavy and touch them to two battery posts. That's how he used to clear pins on his old dragline. I'm going to try plan RickB first.
